Orbi WiFi 7 RBE973
Reply
Where can I download readyshare.exe?
Dallaspilot
hThis may be part of ReadySHARE Access, but it is not available for download or I cannot find it.
ttp://www.netgear.com/readyshare is suggested, but the file is not available there.  This is necessary to set up a USB hard drive.
Message 1 of 5
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: Where can I download readyshare.exe?
Hello @Dallaspilot,
Welcome to the community!
What model number and version of the Netgear device that you have?
That file is not necessarily needed to get the USB working. Once you plug in the USB to the router, you should be able to map the drive through "\\readyshare_USB name".
You may want to verify the exact syntax by accessing the admin page of your router and go to ReadyShare then look for Share Name. See example below.
Keep us updated.
Message 3 of 5
All Replies
Dallaspilot
Modifying my request above -- The file I need is readyshareconnect.exe
Message 2 of 5
ElaineM
Hello @Dallaspilot,
Keep us updated.
Message 3 of 5
Dallaspilot
I'm using the Netgear Nighthawk 1900ac router.  Your solution worked; thank you.
Message 4 of 5
ElaineM
That's good news @Dallaspilot!
Thank you for giving an update as well.
Have a great day!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 11660 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
