Reply
Where is the Transmit Power Control for my R6080 AC1000?
tdkehoe
Where is the Transmit Power Control for my R6080 AC1000? I can't find it in the Wireless Network Basic panel.
Message 1 of 4
Re: Where is the Transmit Power Control for my R6080 AC1000?
There is a manual for the R6080 somewhere at the end of this link:
>>>> R6080 | Product | Support | NETGEAR <<<<
See Table 4. Router factory default settings.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
tdkehoe
I found a doucment on the Netgear website saying that Transmit Power Control is a feature on the R6700, R6900, R7000, R7500, and R8000. Not on the R6080.
Message 3 of 4
antinode
Guru
> I found a doucment on the Netgear website [...]
   Thanks for the helpful link.  Or did you expect the non-psychics in
your audience to guess which "a doucment on the Netgear website" you
were reading?  (There might be more than one document there.)
> [...] saying that Transmit Power Control is a feature on the R6700,
   If you found a list of routers which offer that feature, and your
router is not on that list, then how amazing is it that you can't find
that feature on your (low-end) router?  Do you expect all router models
to offer all the same features?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 759 views
  • 0 kudos
  • 3 in conversation
Announcements
