Orbi WiFi 7 RBE973
Reply
Where is the time zone setting on Nighthawk X4S R7800
fractaloon
Follower
I was trying to change my timezone and couldn't find the setting.. Everything I read said it is in Advanced tab under Security -> Schedule.  It wasn't there and I found another post saying as much but no solution as to were to find it. I looked through all the menus and eventually stumbled across it in...
Advanced tab under Administration -> NTP Settings
Message 1 of 3
Accepted Solutions
Re: Where is the time zone setting on Nighthawk X4S R7800
It can depend on the firmware installed on the device.
Things have moved over time.
So if that doesn't work, check your firmware version.
Message 3 of 3
All Replies
Kitsap
Master
Advanced -> Administration -> NTP Settings
See attached.
Message 2 of 3
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 942 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
