Reply
Which firmware to update R7900P
Snowchopper
Follower
Which Firmware do I use to update the above listed Router? I use IOS and Windows with this router and also an Epson WF-7220 printer
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 1 of 3
antinode
Guru
Re: Which firmware to update R7900P
> Which Firmware do I use to update the above listed Router? [...]
   Which firmware is on it now?
> [...] I use IOS and Windows with this router [...]
   Shouldn't matter.
   Visit http://netgear.com/support , put in your model number, and look
for Downloads.  (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".)  Find the kit(s).
Download the kit(s) you want.  Read the "Release Notes" file for
instructions.  And/or, while you're in the neighborhood, look for
Documentation.  Get the User Manual.  Look for "firmware" and/or
"update".
Message 2 of 3
myersw
Master
With the crappy firmware Netgear is putting out for the last year, if I were you and the router was working the way you want I would hesitate to update firmware. Probably have issues.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 409 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
