Reply
Why cnnaot downgrade the firmware?
kitkit3577
is my router problem?
otGpy8
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 12
IrvSp
Master
Re: Why cnnaot downgrade the firmware?
Not sure but I don't know what version you now have? The last one, .60, was PULLED from the Auto D/L site... and NG probably removed the file and NOT the catalog entry...
Message 2 of 12
kitkit3577
my version V1.0.9.60_10.2.60
now, i cannot downgrade to any version.
Message 3 of 12
IrvSp
Master
Have you tried to? Auto-Update which uses the router interface uses the server and there is NO UPDATE on it that is newer.
Downgrades you MUST do manually. Go to Support, enter the router model, and then DOWNLOADS. At the bottom of the list is PRIOR VERSIONS. Open that up, use the + to see them, select the one you want, d/l it (and read the README to) and then UNZIP it. From the ROUTER UPDATE page browse to find the unzipped file (.CHK extension) and then update.
Message 4 of 12
antinode
Guru
> [...] i cannot downgrade to any version.
   "cannot" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
Message 5 of 12
kitkit3577
i try download all version.
but only newly can update
other is show this error.
Message 6 of 12
IrvSp
Master
What versions did you d/l?
What was the error for each or are ALL the same?
Detail EXACTLY what steps you took to d/l, unzip and what files you got, and how you tried to install them and where from please.
Message 7 of 12
kitkit3577
My r7000 is purchase on yesterday.
I only can downgrade to these version.
R7000 Firmware Version 1.0.9.34
R7000 Firmware Version 1.0.9.42
R7000 Firmware Version 1.0.9.60
These 3 version not support using router update to merlin.
when i try downgrade older than 1.0.9.34 firmware will show my first image error
i would like to know what problem or netgear blocked update to third party firmware?
Message 8 of 12
IrvSp
Master
I don't know why you can't do older? Should be no reason that I can think of.
Merlin, better of checking HERE.
Message 9 of 12
kitkit3577
i don't know r7000 has new verion or not.
when i try third party firmware or older than 1.0.9.36 cannot update
Message 10 of 12
IrvSp
Master
Go to the SUPPORT page for the R7000 and look at the D/L's, The latest is on the top and ALL prior releases are at the bottom of the list under PRIOR VERSIONS.
I have never had problems going back. Please detail what you did, where you got the file from, where you UNZIP'ed to, and then what you used to install it. Screen captures would help here.
3rd Party, check with them.
Message 11 of 12
z43204320
回复: Why cnnaot downgrade the firmware?
I have the same question like you.I can only change FW for 3 version.
1.0.9.34
1.0.9.42
1.0.9.60
Finally,I succeed.By using nmrpflash to upgrade or downgrade.
You can try it,too.
This is https://github.com/jclehner/nmrpflash
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 2374 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
