Reply
Wi-Fi Stops Working when Wired Connection is Plugged in
mahirkothari062
Follower
So just moved into a new apartment, got my wifi set up. I want to connect my TV and an IPTV box via a wired connection and was able to at my last apartment. However, the moment I connect the ethernet cables, the wifi stops working and the wired connections don't work either. The moment I unplug the wired connection the wifi comes back on and I am able to access the internet.
What settings do I need to change in order to have the wireless connections and wifi together. As mentioned before, I was able to do this earlier but now I can't use the wired connections at all.
Model: AC2100|Nighthawk AC2100 Smart WiFi Router
Message 1 of 2
Guru
Re: Wi-Fi Stops Working when Wired Connection is Plugged in
What actual modem/gateway are you connecting to??
Current Setup: CM2000-> SXK30-> GS716v2-> Arris W31 x2-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 79 views
  • 0 kudos
  • 2 in conversation
Announcements
