- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wi-Fi connection lost with security Firmware V1.0.9.18_1.2.27 patch on R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
After installing V1.0.9.18_1.2.27 on my R7000 router, I lose WI-Fi connctivity on both the 5 and 2.4 Mhz bands. The hardware Eithernet connections stay active, and otherwise the router behaves normally. I installed the new firmware about 48 hours ago, and I can restore functionality by powering down the router twice. ( the first time it won't work, second try is a charm.) This is now required about every six hours before it loses its mind, so I have a new thing to do at breakfast and dinner each day. Is there a known bug in this firmware for this and is there a fix coming. I think it's a bit unfair to have to pay for support when all I needed was to keep the secuity patches in the unit fresh.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi kemuri1000,
Please try this firmware.
https://kb.netgear.com/000053870/R7000-Firmware-Version-1-0-9-26-Hot-Fix
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wi-Fi connection lost with security Firmware V1.0.9.18_1.2.27 patch on R7000
I was having the exact same problem with V1.0.9.18_1.2.27. I downgraded my firmware to V1.0.9.14_1.2.25 about 10 minutes ago and working good so far. I will know in several hours if the wifi drops on this version also.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same problem here after upgrade to V1.0.9.18_1.2.27 Wifi doesn't work for my mobile devices (Samsung S7 and Xiaomi redmi note 4) but works ok with Mac book and Mac book pro. Reboots do not seems to clear it (temporarily) for me. So downgrading now. Looks like a pretty big regression problem. (Unless this is a flaw in Android on the client side)
- Also the hotfix V1.0.9.20_1.2.28 does not solve this problem
- Factory reset and restore of the con figuration also does not solve this problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Going back to V1.0.9.14_1.2.25 solves the problem immediately (no factory reset / reread config needed).
Now figuring out how to file a bug with Netgear
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had the same issue after the update a few devices won't connect anymore
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not so hot about downgrading my security patches to keep this up and running. But i'm also not so happy about buying new gear to keep up and decommissioning my perfectly good router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You do not need to buy a new router. Option 1, wait for the new firmware from NG. Option 2, flash an alternative stable firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well in my case I have over 35 wireless devices in my home including a Ring doorbell and several Chromcasts that I rely on for entertainment. So waiting isn't much of an option for me. I picked up an Orbi 3 pack at Costco, added all my MacID (close to 50) addresses and I'll return it after all the smoke clears. Or not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's a good choice, but not everyone can afford a new router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Updated to V1.0.9.18_1.2.27 today (20180202) and having the same issues as most people
5GHz and 2.4GHz working on some devices (PC/laptop), however my Galaxy S7 cannot browse.
Please fix this immediately! Doesnt this get QA'd? 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi kemuri1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi kemuri1000,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
