Reply
Wi-Fi not available
mattegem
Wi-Fi not available
Both bands have disappeared, leds off on the router. Tried reset to factory settings, firmware updated but nothing. Internet is available I don’t know what else to do….
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 4
Accepted Solutions
Kitsap
Luminary
Re: Wi-Fi not available
You are welcome.  Please mark as resolved.
My setup: Comcast -> Netgear CM2050V -> Netgear R7800 (Voxel v. 1.0.2.89SF)
Message 4 of 4
All Replies
Kitsap
Luminary
You have managed to manually turn off the Wi-Fi radios.  Neither firmware updates or reset to firmware default settings or cycling the power will change the state of the on/off switch.  Once turned off, it stays off until manually turned back on.
When looking from the front of the router, the last two leds on the far right are a combination indicator/switch.  The second one in is the Wi-Fi radio on/off switch.  Press and hold for two seconds then release.  Your Wi-Fi radios should come back on.
This information is in the manual.
Message 2 of 4
mattegem
I thought that were only leds not also buttons. I love you thanks mate! Smiley Very Happy
Message 3 of 4
Kitsap
Luminary
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 368 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
