Orbi WiFi 7 RBE973
Reply
WiFi Coverage at Home...??
RWMosser
Question is:  Have R6250 dual Band Router - Range, within home seems to be reducing.  Zoom meetings freeze & break-up more often.  Distance w/in home from router to TV, PC, & frequent iPhone usage is about 75-feet.  What should I do to increase Wi-Fi Range w/in house??  Internet is 150mbs cable.  My solution to date has been to string a temporary e-Net cable from modem to PC (Pain).  Thx,  - Russ
Message 1 of 4
Guru
Re: WiFi Coverage at Home...??
You could look at a mesh system like netgear orbi. I'd recommend the triband setups.
Message 2 of 4
RWMosser
Thx, but I'm not sophisticated enough to understand: "CM2000-> Arris AX11000 W31-> GS716v2-> WAX***-AP"...   Don't need the Lambrogini solution.  Was just thinking of a newer NetGear router?  🙂   Tri-Band would do what for me..??   - Russ
Model: R6250|Smart WiFi Router (AC1600)
Message 3 of 4
Guru
That's just my signature of what my current setup is.
I was just stating the tri-band orbi setup is pretty solid and does great for coverage.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 456 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
