Discussion stats
  • 1 reply
  • 6224 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Wifi ac slow speed on download
Equipments:
Windows-8.1 computer connected by 5e Ethernet cable to a Gigabit Router
iPad Air-2 iOS 8.1.3 connected with wifi AC to the network
Netgear R7000 router (up to date)
Problem:
I can upload a big video file of 877Megs to the windows-8.1 computer
in 20 seconds so about 43Megs/sec !
But to retrieve the same file or other big file from the same computer
I only obtain around 14Megs/sec speed...3 times slower...
Questions:
Should I see the same speed from both way ?
Or is it normal to have a slower download ?
Could it be that slow speed on download is du to the fact that iPad Air-2 cannot write a file on is memory faster then 14Megs/sec ?
Anyone else see the same things ? Or see same speed both way ?
Message 1 of 2
Highlighted
Re: Wifi ac slow speed on download
It's definitely not abnormal to see different read/write speeds. Whether it's the Windows 8.1 computer or your iPad is hard to say without doing more tests:
- Test downloading to the iPad from another computer on the network.
- Test downloading from the Win8.1 computer to another computer on the network.
You need to do a little more troubleshooting and go about this methodically/scientifically to get your answer.
Message 2 of 2
