Reply
Wifi connections no longer showing up
mnlamay
Follower
My wifi connection names are no longer showing up on my phone or computer. I can confirm that my modem is working fine along with my wifi service. The router no longer has the lights lit up for 2.4GHz nor 5GHz. I assume the connection has something to do with these lights being off. I have tried resetting the device many times. My app is also not recognizing a device anymore. I have also tried to re-add the device to my app but it ask's to connect to my routers wifi and because nothing is populating I am unsure what to do. Please advise! Thanks!
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Guru
Re: Wifi connections no longer showing up
Have you tried pushing and holding the wifi on/off button for 2 seconds on the device?
They're pretty easy to get hit and get disabled. And a factory reset doesn't clear it out as its a hardware disable.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 111 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
