Discussion stats
  • 2 replies
  • 7601 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Wifi not in range help?
Hi, this is my second ac2350(r7500) the problem is , i installed everything , got the internet connection wired no problem (120mbps) but when i connect through wifi like around 25 ft away from my router , the ssid says is not in range.. This is crazy. Help please , do i need any tweaking ,
(firmware is up to date) or should i just get ac1900 .
Thanks
Message 1 of 3
Highlighted
Re: Wifi not in range help?
More info would help, does the devise connect at a closer range ? If so then maybe you have hit a dead spot and could get a range extender. If not then maybe try a different WiFi adapter.
If You Got Em....I'll Chew Em!
Products: (MC227BL|VMS5140P|AAD1001|AC1001|RAX200|XR700|CM1100|CM1000|C7500|R7500|
Netgear & Arlo Beta Tester
Message 2 of 3
Highlighted
Master
Hi, OP, keep in mind. WiFi is between router and client. Client side could be weak link. I use R7500 and all WiFi connections on either 2.4GHz or 5 GHz work just fine.
Message 3 of 3
