Reply
Wifi router not visible
Radahl
Tutor
All off a sudden my WiFi isn't visible for any unit. Neither iPad, iPhone or my Dell laptop (Windows 8).
I can do enything if the network cable is connected and when logging into the router it all looks fine.
Have upgraded the firmware to the latest, restarted all units (router, laptop and mobile devices) but nothing works.
Previously I have had the same problem with a HP laptop on Windows 10 and that is not solved regardless what I do.
But now no units can connect.
Any ideas?
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 11
Accepted Solutions
Guru
Re: Wifi router not visible
What version of FW did you upgrade too?
Do a factory reset on the router. Either from the routers web page or the back button.
Check to see after the reset if your devices sees the default NG SSID names listed. Should see two. If so, go in and set up new SSIDs and give new PWs.
Ensure that each radio is enabled as well under Advanced/Advanced settings/Wireless settings.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 11
All Replies
Guru
Testing
Message 2 of 11
Radahl
Tutor
Worked fine! :-)
Upgraded to V1.0.3.10 but that was AFTER I got problems.
Any clue why it happened and if it's a common problem?
Message 3 of 11
schumaku
Guru
WiFi switched off by hardware button? Check what the cat is doing overnight.
R9000 v1.0.3.10 does reliably keep the WiFi up and running here - and I've not seen many similar reports, too.
Message 4 of 11
Radahl
Tutor
Don't have a cat! :-)
Router has been on the entire time.
Lost it from one day to another, could even be during the day as I didn't check this morning (I'm in GMT +1 timezoon)
Message 5 of 11
Radahl
Tutor
By the way...
Lost WiFi on V1.0.2.40 (belive it was...) and didn't regain on upgrade to V1.0.3.10.
Didn't until after hardware reset.
Message 6 of 11
schumaku
Guru
Ok, we're in the same time zone.
The WiFi button/LED (second LED from the right) and the 2.4GHz, 5GHz and 60GHz LEDs are on?
Message 7 of 11
Radahl
Tutor
They do!
Works fine now after the HW reset.
You say that you haven't seen any reports of this error on V1.0.3.10.
How about previous versions...?
Message 8 of 11
Guru
Ugrading to v1.0.3 is a major version change. There may have been some changes that didn't take effect until a full reset was done. Something probably got hung up.
I recommend doing a factory reset after upgrade to a major FW version. Then set up from scratch. Then save off a new configuration to file for this version for back up if you need. Normally you should be able to do a FW update with out having to reset, however seems to be in this case, you needed one.
Testing
Message 9 of 11
Radahl
Tutor
Great!
Thanks' a lot for your help and support guy's.
Absolutely nothing personal but I hope I don't have to chat with you again... ;-)
Message 10 of 11
Guru
Glad it's working. Feel free to come back if you need us.
@Radahlwrote:
Great!
Testing
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 6550 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
