Reply
Wifi speed is all of the sudden slow in the past week or so, or so it seems
Fasterjake
Follower
Hey guys so long story short my wired speed is fine, hitting 660mbps+. My wifi normally sits around 247-270+. Randomly this week my wifi is sitting at like 25-50mbps. Just talked to comcast they dont see anything wrong and checked to see if my router was up to date. It says it is, any ideas what I should do or is it possible for maintenance or anything. Get back when you can. Thanks guys.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Guru
Re: Wifi speed is all of the sudden slow in the past week or so, or so it seems
what modem are you connected to?
What firmware is on your router? (please don't say "the latest" it doesn't help)
when the wifi speeds drop, do the wired?
Is it 5ghz speeds that are low or 2.4ghz or both?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 358 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
