Reply
Wifi will not turn on and login not connecting
jeffmarks
Follower
First weird thing is the only r7800 I can find also says AC2600 but on the back of mine is says AC3200. Quite confusing. This morning unprevoked my router which I shelled out $400 dollars for mear months ago stopped broadcasting WIFI. The light is off on the front button and SSID's are gone. So attempting to find out what was going on I typed its default IP 192.168.0.1 and the login and setup pages are inaccesible. Doesn't show a page at all. Does anyone hopfully know what might be wrong? Thanks in advance!
PS. The ethernet ports are still functional but still no setup pages.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
Guru
Re: Wifi will not turn on and login not connecting
did the wifi on/off button get hit?
Push and hold it for 2 seconds.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 94 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
