Reply
Will using an ethernet switch make my nighthawk useless?
Answer
Follower
Will using an ethernet switch make my nighthawk useless for Xbox One Gaming? :confused:
Message 1 of 6
fordem
Mentor
Re: Will using an ethernet switch make my nighthawk useless?
An Ethernet switch can be considered as a way to expand the number of available Ethernet ports on the router - it won't prevent the router from operating normally - and is unlikely to make it useless.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Message 2 of 6
Konceptz804
Be sure to use a gigabit switch and not a fast Ethernet.
Message 3 of 6
jsaelman
And also check if the ethernet switch supports QoS.
Message 4 of 6
Temporel
Novice
rofl, why ? Unless you need the speed, a 100Mbs will do the job.
Message 5 of 6
Babylon5
NETGEAR Employee Retired
A gigabit Ethernet switch will allow for much faster LAN to LAN and WLAN to LAN transfers and is in any case consistent with the fact that the router’s switch is also gigabit. Why buy a 10/100 switch when the cost of gigabit is not much more?
____________________________
Working on behalf of Netgear
My name is Andy
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2002 views
  • 0 kudos
  • 6 in conversation
Announcements
Orbi WiFi 6E
