Orbi WiFi 7 RBE973
Reply
Windows XP settings for wireless connection
Flecken
Follower
Think Pad, Windows XP recognizes the wireless network but can't connect to the internet.  The message displayed: Windows was unable to find a certificate to log you to the network.......".
What are theWireless Connection Properties for all three tabs: general, wireless networks and advanced that should be chosen for this particular OS and router?
System requirements for netgear product does list XP, so there should be a way to fix this error.
Model: R6080|AC1000 Dual Band WiFi Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 218 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
