Discussion stats
  • 3 replies
  • 2138 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Wired AP for my R7000
I've been using a R7000 running WXRT-Vortex for some time. It's a good router but there are spots with bad signal. Was wondering what would be a good AP to fix it using same ssid and password. I already have Cat6 through most of the apartment...
Thanks,
Gilson
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Highlighted
Guru
Re: Wired AP for my R7000
That's really up to you to decide.  Any Wi-Fi router can be used as an AP as well as many range extenders.
You may want to consider the following factors:
  • Budget
  • Single or dual band
  • 802.11n or 802.11ac
  • Number of dead spots
Message 2 of 4
Highlighted
Hi TheEther,
I was thinking about the TP Link Archer C7. Seems to be a good router on it's own...
Message 3 of 4
Highlighted
Guru
Yup.
Message 4 of 4
