Mit53's avatar
Mit53
Follower
Sep 02, 2021
Wireless hookup to roku
Wifi router isn't connecting to my Roku device, no wireless
connection. Wired, yes.
1 Reply
  • plemans's avatar
    Are any other devices having issues or just the roku?
    Reason I ask is the router doesn't connect to the roku, the roku connects to the router.
    Sounds like a small point but its important in that maybe the roku is the one having issues?
    Are you trying to connect to the 2.4ghz or the 5ghz?
    What roku model is it?
    are you getting an error or not seeing an ssid at all when you search on the roku?
