Reply
Wireless turning off
shaka999
Follower
Hello all,
Just hooked up a new R7000 and was really impressed by the range. Too bad I'm already having problems. The wireless is just turning off for both the 2.4 and 5Ghz bands. If I reboot it comes back on and works great. The wired connection works fine all the time.
Anyone have thoughts on why it would shut off? I'd hate to have to fight the crowds tomorrow just to return this ....
Message 1 of 2
Retired_Member
Not applicable
Re: Wireless turning off
Several things to check, Make sure you're using correct power adapter. Could someone be pushing the radio on off button on router? Check to be sure it's not set to turn off by scheduled. Try a factory default. Update/reinstall FW
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5385 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
