Reply
Wireless
theshield
Guide
Wireless
  Hello to All , I have a ?  I would like to connect a Ethernet USB 3.0 Adapter to gain some speed , however, this connects from the tower to the modem which of coarse disables my whole home wifi since I will not be able to connect the modem to the router .  Is there any way possible , to add a device or change something to work around this ?
Thank You
Hank
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 4
antinode
Guru
Re: Wireless
> [...] I would like to connect a Ethernet USB 3.0 Adapter [...]
   To _what_?
> [...] to gain some speed , [...]
   Compared with what?
> [...] however, this connects from the tower [...]
   What is "this"?  What is your "the tower"?
> [...] to the modem [...]
   What is your "the modem"?  Why should anything other than your
router's WAN/Internet port connect to your modem?  Why would this
(unspecified) "Ethernet USB 3.0 Adapter" connect to anything other than
a LAN Ethernet port on your router?
> [...] which of coarse disables my whole home wifi since I will not be
   You lost me.  What, exactly, is connected to what, exactly, now?
What are you proposing to change how?
   What is the actual problem which you are trying to solve?
Message 2 of 4
theshield
Guide
Re: Wireless
  I have Charter Spectrum Internet 200mbps subscribed , but I only have a 100mbps card reader in hp pavilion 500-a60 . I do avg 96.3mbps , but I wanted to bump it up . A friend loaned me a Ethernet USB 3.0 Ethernet adapter, however it has to connect to the only 3.0 port I have on the back of my desktop, then I connect my cat 6 cable to the USB and the other end to the Charter Arris Modem . This , got me up to 160mbps on Ethernet speed , but with it is  connected this way , I then can not connect my modem to the Wan port on my router , as a result I loose my whole home wifi . The Ethernet USB adapter is required to be connected to the modem . I just wonderd , if there was a way to get whole home wifi , if the modem is not connected to the Wan port on the router. Perhaps, I could install a separate system .
Hank
Message 3 of 4
antinode
Guru
Re: Wireless
> [...] I only have a 100mbps card reader in hp pavilion 500-a60 . [...]
   "card reader"?  Ethernet adapter?  ("m" = "milli", "M" = "mega".
100Mb/s?)
   HP claims that the motherboard in this thing has "1 PCI Express
half-length mini card socket".  I'd look for a (cheap) gigabit Ethernet
card which would fit into that (assuming that it's not already in use).
      https://support.hp.com/us-en/document/c03786042
> [...] then I connect my cat 6 cable to the USB and the other end to
> the Charter Arris Modem . [...]
   Why?
> [...] Why would this (unspecified) "Ethernet USB 3.0 Adapter" connect
> to anything other than a LAN Ethernet port on your router?
   Still wondering.
> [...] The Ethernet USB adapter is required to be connected to the
> modem . [...]
   Says who?
> [...] I just wonderd , if there was a way to get whole home wifi , if
   No.  Connect the modem to the WAN/Internet port on the router.
Connect any other Ethernet cable to a LAN port on the router.  It's not
complicated.
> [...] Perhaps, I could install a separate system .
   Not a good idea, whatever it means.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 291 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
