- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
With Readyshare Vault, how can I exclude one individual file from backup?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes - that is correct and a commonly used technique.
Again, just to confirm, I'm responding with regard to ReadyNAS Vault. Can you confirm you are using ReadyNAS Vault (as opposed to ReadySHARE Vault)?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: With Readyshare Vault, how can I exclude one individual file from backup?
Hello StanH,
I am responding to you this post to keep this alive and get ReadyNAS Vault people see your concern.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @StanH,
I'm not sure if this is about ReadySHARE Vault (backup solution to hard drive attached to your router) or the ReadyNAS Vault (the cloud backup solution built-in to ReadyNAS devices and usable on other hardware like laptops and desktops). I'm only able to provide guidance on the latter, as a member of the ReadyNAS Vault support team.
If you are confused about which service, please check this grid: http://kb.netgear.com/23703/What-is-the-difference-between-the-NETGEAR-ReadySHARE-Vault-and-the-NETG...
Here are two related support articles detailing how to add exclusions your ReadyNAS Vault backup jobs.
http://support.readynasvault.com/hc/en-us/articles/208283106-Web-Portal-Creating-Modifying-Backups
If you need any additional help, just email us directly at support@readynasvault.com. One of our team members will respond and help over email or set up a screen share if necessary.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StanH: The answer matters - and you've ignored the question more than once. Please respond. If you are talking about a USB drive connected to a router, you are referring to ReadyShare vault.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, they are quite different solutions.
While they have similar sounding names and both provide a form of data protection, ReadyNAS Vault is a separate site cloud backup service (also provides desktop applications and mobile apps for backup and access from other devices) and ReadySHARE Vault is a local backup solution to a drive attached to your router.
ReadyNAS Vault has a small free plan and paid subscriptions on top. ReadySHARE Vault is free (except that you have to provide the drive).
A detailed breakdown of the differences can be found here:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you post back on what router you are using, I can move this thread into the correct forum area (where you will be connected to the right folks).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It took a while to sory out where this question belonged - since it is the R7000 ReadyShare, it belongs here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
