Reply
Working with Centurylink ONT
rkrumrey
Model: R6220v2|AC1200 Smart WiFi Router with External Antennas
Message 1 of 6
microchip8
Master
Re: Working with Centurylink ONT
Dude, at least describe your problem.
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.89SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 6
rkrumrey
I've been having trouble getting an internet signal to my R6220 from my CenturyLink fiber account.  This is a new installation with no existing modem to obtain PPPoE credentials from.  Has anyone successfully used an R6220 directly hooked to the ONT?
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Message 3 of 6
antinode
Guru
> [...] no existing modem to obtain PPPoE credentials from. [...]
   Ask your ISP?
   A quick Web search suggests that CenturyLink may use a VLANID on the
WAN.  Whether the R6220 allows you to specify one is not clear.  My
quick look at the R6220 User Manual found nothing relevant.
Message 4 of 6
rkrumrey
I've called my ISP many times.  They've always told that my region only does IPoE for fiber, not PPPoE.  I've asked them to create credentials and manually enter them so I can match them to have my router's info reconcile with theirs and no dice.
Message 5 of 6
antinode
Guru
   Then what leads you to believe that you need PPPoE credentials?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 328 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
