- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wyze Doorbell connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wyze Doorbell connection
What modem/gateway is the router connected to?
What firmware is on the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Tallguy_AZ wrote:
Firmware is latest up to date.----Is it? without an actual number, its tough to confirm. The internet coming in is straight off the antenna on my roof, which receives data from a tower about a mile away. Ethernet comes into the internet port of the router.----seems like we've been running into a lot of issues with broadcast wireless lately. Not sure if its because the company who's broadcasting it has their own router on their end and it creates a double nat (which some devices stuggle with) or whats going on. I've see some be able to connect by putting their router in access point mode. Others simply contact their ISP and ask them what settings are needed to use their own routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll email my isp to see if they have any input.
- Mark as New
- Bookmark
- Subscribe
- Permalink
do you have an unmanaged switch sitting around?
if so, plug it into the dish and connect a few device. If more than 1 works, the ISP has something managing dhcp from their end
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
LInksys has an access point mode. Just put one in access point mode and connect it. If you have it in access point mode and can still get multiple devices working, it points at the isp having its own routing functions.
You can do the same with netgear but can run into issues if the ISP isn't using their routing fuctions. Can be a pain to get back in and disable access point mode. Its usually faster to factory reset and reinstall and I don't want you to have to do that to your primary router.
