- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
X10 R9000 Wireless Roaming
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently changed to a X10 and had previous wireless roaming setup. The 2.4 band is fine. However with Netgear wifi analystics app I can See 2 different 5ghz bands. They are named Identical. Anyone have any suggestions? The security is the same also.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi itskamel,
The R9000 does not support wireless roaming. It will be listed as a different network even if you name it same as other networks.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X10 R9000 Wireless Roaming
Hi itskamel,
On your device network settings, can you detect two 5Ghz?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes, I can. Whats the fix for that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi itskamel,
Your computer should support AD connection for you to able to connect to the 2nd 5Ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So its created automatically? but named the same? no where to change the name of the 2nd 5ghz network?
I am currently showing 2 5ghz networks. the 60hz network is named with a -60hz on the end of it. are you refering to the 60hz network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The r9000 has band one is a 2.4 ghz band, band two is a 5 ghz band, band three is a 60ghz AD band. Here is a link for the product sheet of the router look at page 13
https://www.netgear.com/images/datasheet/networking/wifirouter/R9000.pdf
may be you are seeing a old image from your old router or another router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I guess it could be one of the access points. is there any software you can recomend that can help me pin point what device this is coming from? My phone is the one that sees 2 5ghz networks. also i seen it on a frends phone. I never had this happen until i switched to the r9000. previously i was using a EA9500. so i was just assuming that it was the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
after checking it is not one of the access points. it is the r9000 that is seperating itself. when i use wifianalystics it shows my other 2 access points under the same name and channel numbers. the r9000 is not listed under it but another by itself.. any help would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi itskamel,
- Mark as New
- Bookmark
- Subscribe
- Permalink
So it just doesnt support it on the 5ghz band? Because the 2.4 doesn't do that.
