- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
X10 R9000 & SilverStone DS222 = no-go?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X10 R9000 & SilverStone DS222 = no-go?
ReadyShare has limited support for USB devices. The arrangement you describe is well outside its capabilities.
You can get an idea of what you can use from this page:
Will my USB drive work with ReadySHARE | Answer | NETGEAR Support
For serious networking use Ethernet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It all looks like it can't support this particular device. But I have read Netgears support claim that it's supposed to supports way more than 1TB drives and among others EXT4 file systems. So I don't buy that just yet.
The cabinet does not require any specific drivers as far as I know. I can even connect it to my Android smartphone without any problems! Haven't tried that with EXT4 thou.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hmm. Don't forget that Windows and other OSs come with built-in support for a pile of kit.
The OS on a router cannot hope to match that.
But don't take my word for it, I am just reporting what I have read here over the years. This tells me that no one has managed to get stuff like that to work. Maybe you have the magic touch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I assume you are powering this enclosure externally and not hoping the router will power it. That said as others have noted this is probably out of the realm of the router being able to support it.
I would suggest you look into an external NAS like I did rather then trying to get the router to handle NAS duties along with routing and network device support. My thought is routers were meant to route and support networks and you use another purpose built external network attached NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have seen such enclosures with embedded RAID controllers (mostly unmanaged, virtually zero monitoring capabilities, ....) which seem to be recognized by some devices as a single storage volume, while other systems (mostly Linux) does detect them like n individual storage devices - same on other embedded devices ReadyNAS, Asustor, QNAP, Synology NAS, ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are probably right. But I came here in hope to get another answer 😄
Any idea if DD-WRT would solve it? It did work in one of my previous Linksys routers with DD-WRT. But I belive it worked with Linksys stock FW aswell, so that might not tell you anything.
Yes, I power the cabinet with external power, even thou USB3 should supply enough power.
Buying a NAS would possibly be the simple but expensive solution. But I’ve been using my USB-drive connected to my routers as a NAS for several years and it does all I ask for flawlessly. So I can’t see why I should be forced to buy another device when I can be done simpler and cheaper. Especially when I have bought one of the most expensive home-routers on the market.
The only managing you can do to this device is switch between how it’s presenting itself to the host it’s being connected to. You can choose between RAID0, RAID1 and two separate drives.
So when in any RAID config it looks like any single USB harddrive for the host, my X10 router in this case. The host doesn’t know the cabinet has two drives inside. Non I've tested anyway. I’ve used it on my Linux laptop and it does not see it as two drives either.
The switch to do this is inside of the cabinet and cannot be changed once you have data on the drives. Changing it will wipe the drives.
As mentioned before, I have another dual drive USB-cabinet, but this one is from a no-name maker. It works exactly the same. The only difference is that the X10 router discovered this one after it had been connected for a few days! I would really love an explanation how that could be!?
Thanks for your inputs!
- Mark as New
- Bookmark
- Subscribe
- Permalink
All these embedded devices are at least one decade behind any decent desktop or server Linux distro. Kernels are historic, the UPnP code is from the early days, ... that's all. And the SoC makers deliver mostly outdated dev kit code. ODM integrating things often standardize on the "most basic" common available code. Figure. That's all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you found a solution. Have run DD-WRT on many routers, starting with a WRT54G in 2006. I am aways hesitent to suggest 3rd party to someone as I do not know their technical level. I do suggest Voxel's, but he is close to Netgear in look and feel with a few fixes or add ons and installs and removes just like a manual Netgear firmware install.
