Reply
X10
Bdillon1
Follower
X10
I am trying to setup this damn router and I keep getting this prompt that says the ethernet cable is not connected but it sure as heck is! Everything lights up, my mac connects to it but the browser says I am not connected... I'm about to throw this thing up against the wall. But it was too frickin expensive! Can't get support because it was used! Any help out there?
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 2
antinode
Guru
Re: X10
> X10
   Not a model number.  Look at the product label.
   Is that accurate?
> [...] I keep getting this prompt that says the ethernet cable is not
> connected but it sure as heck is! [...]
   Which part of it "sure as heck is" "connected" to _what_?
> [...] Everything lights up, [...]
   Define "Everything".  Color and activity of the lighted "Everything"?
> [...] my mac [...]
   Not a very detailed description of anything.
> [...] connects to it [...]
   How?
> [...] but the browser says I am not connected...
   What is the actual error message (or whatever you're seeing)?
Copy+paste is your friend.
> [...] Can't get support because it was used! [...]
   You might be able to buy some.
> [...] Any help out there?
   With an information-free problem description like this, I wouldn't
depend on getting much.
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 240 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
