Reply
X10
cemmanuel1nyc
Follower
X10
Anyone having issues with new firmware update, 1.0.5.36? Every three days have to reboot router. Lose all access to router setting, including Nighthawk app. Looks like ill be switching back to older firmware. 10 years using netgear router's and every time a new firmwar, they always mess up something.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 2
Guru
Re: X10
It does seem like the latest round caused issues across multiple product lines.
Did you ever try a factory reset/reinstall? its usually what I recomend if there's issues after a firmware upgrade.
If that doesn't help, then I recommend the downgrade.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 135 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
