Reply
X4S R7800: No 2.4Ghz wifi
Mimss
Initiate
Hello,
I have a NightHawk X4S R7800 V1.0.2.80. The settings of the Wifi 2.4Ghz is enabled, SSID is broadcasted but does not appear on any of my devices (raspberry pi, phone number, laptops).
You can see in the print-screen.
Is there a problem with the firmware?
Thank you
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 4
Guru
Re: X4S R7800: No 2.4Ghz wifi
Did it start after a firmware update?
Have you tried a factory reset and clean install (not from backup)?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 4
Mimss
Initiate
Re: X4S R7800: No 2.4Ghz wifi [FIXED]
As stupid as it was: I rebooted the routeur and voilà!
Message 3 of 4
Guru
Glad it fixed the issue!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 165 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
