Orbi WiFi 7 RBE973
Reply
X4S nighthawk cannot SAVE device priority
nasu
As shown in earlier thread (marked solved but its not).
Reseted to factory settings, updated and rebooted. But cannot save / keep high priority on connected devices.
after save it goes to
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 7
Accepted Solutions
JamesGL
Master
Re: X4S nighthawk cannot SAVE device priority
Hi nasu,
Try using other web browser when configuring the router.
JamesGL
Community Team
Message 5 of 7
All Replies
coolguy949
Apprentice
I can't see your images for some reason. What type of device is it? I can try on mine and see if it works. So far saving priority has worked fine on all my devices. If you updated your FW after you first got it, you should factory reset it before setting it up. I had a few issues after I upgrade and they were resolved by doing a factory reflash after the firmware upgrade and starting over with my settings from scratch.
Message 2 of 7
nasu
When images was added i tapped something like this" hidden folder" but now i cant change it..
so images again.
and after save
Message 3 of 7
nasu
Images gone again, Dont know why,,,
Message 4 of 7
JamesGL
Master
Hi nasu,
JamesGL
Community Team
Message 5 of 7
nasu
..settings gone again. A few days prioroty was ok but now high settings were low and so on..
Oh dear.
Message 6 of 7
JamesGL
Master
Hi nasu,
Try changing the password of your routers page maybe someone from your network keep on changing it.
JamesGL
Community Team
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 4431 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
