Orbi WiFi 7 RBE973
Reply
X6 R8000 - All LEDs are flashing
kukstern
Follower
Hi,
I suddenly lost my Internet connection, and when I checked on the router it was just flashing on pretty much all LEDs. I restarted it a couple of times and tried to reset, but still the same.
I found another PSU with same specs, but still the same.
Is there anything I can do about it?
/Kennet
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Guru
Re: X6 R8000 - All LEDs are flashing
Did you try a factory reset?
Push and hold reset for 7-15 seconds while powered on?
potentialy the firmware could be corrupt. you could try tftp and/or nmrpflash to recover it.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 602 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
