- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
X6 R8000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Components are purchased with in the last two years so it’s all 4K compatible. Or would it be best to try and hardwired all of it?
It’s all wireless now and when on Netflix I get periods of low signal which makes the picture very low quality so will being wired cure that?
Appreciate the help!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X6 R8000
> It's all wireless now and when on Netflix I get periods of low signal
It might. It depends on what the actual problem is with the wireless
connection (or your Internet connection, or the router itself).
It sounds as if you could run the experiment for the price of some
Ethernet cables, which would quickly provide an actual answer, as
opposed to any speculation (based on little actual evidence) which you
might get here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X6 R8000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X6 R8000
Hi Lnkdes,
Check with the DVD player manufacturer for any recommendation since youtube and netflix works with other device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X6 R8000
Hi Lnkdes,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X6 R8000
Hi Lnkdes,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
