Reply
X6S AC4000 Tri-Band Wi-Fi 5 Router
CSCobb
I purchased the Nighthawk X6S AC4000 Tri-Band Wi-Fi 5 Router and the ARRIS SURFboard 32 x 8 DOCSIS 3.1 Cable Modem.  I registered the modem with Cox Cable, downloaded the Nighthawk app, hooked everything up and...no joy.
The router is not getting internet.  I double-checked with Cox and the modem is receiving the internet.
Ideas?
Are there any known compatability issues with the router and modem?
Any help is much appreciated.
Message 1 of 5
Guru
Re: X6S AC4000 Tri-Band Wi-Fi 5 Router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 5
myersw
Master
First ac4000 is not a router model number just a performance number. Look at the label on the router and you should see something normally starting with a R. So please provide that plus the current firmware version, number not something like latest.
With a new modem and router to be setup you need to do things in proper order.
Power off both modem and router.
Power on modem and let it stablize, maybe 5 minutes or so.
Power on router.
Router should at this point when finished powering up connect to modem and Internet.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 3 of 5
CSCobb
The model number is R8000PNAS-009.
I am unable to find anything about the firmware.
I have tried both suggestions and am still unable to connect the internet - the light on the Nighthawk stays red.
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 4 of 5
myersw
Master
More then one light, so which is red? Use the link to get to get your router's user manual. In there will be a write up about the lights and what the colors mean. Put in your router's model number and you will be taken to location to download the user manual
https://www.netgear.com/support/default.aspx
--Bill
Tesla > Edison
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 608 views
  • 0 kudos
  • 3 in conversation
Announcements
