Reply
X6S (R8000P) needs to be reset every few days
myersw
Master
Re: X6S (R8000P) needs to be reset every few days
Just to show what I think of the r8000p I have sent mine on to a good home. Got tired of waiting for Netgear to get a firmware build that worked. The r8000p was a waste of money and a learning experience at the sametime. Learning experience is that IMHO Netgear has lost their way and are out wandering in the firmware developer wilderness somewhere and cannot find their way out to create a good firmware for the r8000p. .
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 76 of 81
TerryPh
Virtuoso
@myersw and all.
For me, it will be the first time messing around with R8000P, which will be delivered to my house sometime next week.
I have been and Asus routers user for years also and presently at my son's house, Asus RT-AC router has been working nonstop for over 2 years without hickups (with few elective resets due to ISP changes). That is blessing.
I was luckily able to manage my R8000 to navigate through many firmware changes including beta, and effectively nail down to possible theoretical rootcauses of problems, but NG does not have a real fix yet, including the newest fw. So I have to twist the settings to get it stable.
I will try same method with R8000P to confirm my theory.
Best
Terry
Message 77 of 81
jamphi
Hi, is anyone still having this issue as i see the forum has gone quiet on it? I have seen there is a new firmware but i have been hesitant to upgrade incase it isn't fixed? Thanks for help.
Message 78 of 81
Techperson2
Apprentice
I have the R7900 and I did the upgrade about 2 months ago and it seemed to be ok. I have seen a few glitches but think that is a different issue. For the most part it works good.
Message 79 of 81
@Techperson2,
Glad you are liking your R7900, but he's asking about the R8000P specifically.
@jamphi,
I'm running 1.4.1.24 since 9/4.  Love it.  Email is broken in this FW, but otherwise stable and have full speed across all interfaces.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 80 of 81
jamphi
Great cheers. I assume no connection drops like before (assuming you suffered the same?)
Message 81 of 81
Top Contributors
Discussion stats
Announcements
