Orbi WiFi 7 RBE973
Reply
X8 R8500 The router does not work. Before updating firmware, it works well, but ...
segullah
The router does not work. Before updating firmware, it works well, but does not work at all after firmware update.
Operates for ping 1 to 2 seconds and no longer works.
No Wi-Fi.
Wired networks are not connected.
  • Amber Power LED
  • Power LED stays amber
1. Hardware initialization and factory initialization (3030 / 30) failure
2. tftp2 failed. (Changing network settings) Set stick ip, ping not connecting.
What should I do?
My serial number is (4P516A7RA07DF).
I'll be waiting for some good news.
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 14
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: X8 R8500 The router does not work. Before updating firmware, it works well, but ...
Unfortunately, it's not possible to RMA the device if you're outside the US.
You will need a person that's located in the US to do the RMA for you but then the person needs to have the actual defective unit to send it in for replacement.
Message 10 of 14
All Replies
@segullah wrote:
  • Amber Power LED
Check the manual for the meaning of those lights.
>>> R8500 | Product | Support | NETGEAR <<<
See page 174.
Message 2 of 14
SystemCrash
Guide
Did you put it in recovery mode and tried tftp2 and failed? Or did you just try tftp2 without recovery mode?
Message 3 of 14
segullah
Thank you for your response.
Power LED Stays Amber
Message 4 of 14
segullah
It has not failed in recovery mode yet.
Unable to connect because the firmware update did not work and tried to connect to tf tp2, but did not connect to the network.
Message 5 of 14
ElaineM
Did you assign static IP address on the PC?
See the article below for further details.
How to upload firmware to a NETGEAR router using TFTP
Message 6 of 14
segullah
Of course, I put a legitimate IP on the computer.
Only about 2 to 3 seconds of connecting to the machine will cause disconnection.
There is no longer any connection.
You can not use all methods, such as (30 - 30 - 30, factory defaults, tftp. tftp2- ), etc.
Message 7 of 14
ElaineM
Then the unit is already faulty.  I suggest that you contact support to get it replaced.
How do I request a Return Material Authorization (RMA)?
Message 8 of 14
segullah
Thank you very much for your response.
I want to be replaced in U.S.A but now I am in Korea.
R800 is also unavailable to the United States because it is in Korea.
I can't go to the United States during the repair period.
Is there any possibility that there will be an exchange of R8500 in South Korea?
The serial number is (4P516A7RA07DF).
Message 9 of 14
ElaineM
Message 10 of 14
segullah
Can I get an RMA then?
Serial number is already registered.
Unable to receive RMA because it is not registered as a sigillar number.
If you give us RMA, we will ship it to Netgear Repair Centre in Korea.
Message 11 of 14
ElaineM
You can only get an RMA in the US. You can send the device to a relative in the US and he'll be the one to RMA it for you.
For further clarification, please feel free to contact our customer care team at customer.service@netgear.com.
Include your name and the Serial Number of your device in the subject line.
Message 12 of 14
segullah
Thank you for your prompt reply.
I sent an email, but there is no reply yet.
Netgear nighthawk x8 r8500 (serial number : 4P516A7RA07DF)
So I want to get an RMA.
I am currently in Korea, but I can ship goods from Korea to America.
Also, if you send me to this U.S. address, I will deliver it to you here.
Please reply if you need anything to receive the RMA.
Message 13 of 14
ElaineM
@segullah I already made a follow-up with our support team regarding your RMA. Someone from support will reach out to you.
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 3929 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
