Reply
XR500 or X10 wifi signal strength?
Paulie225
Follower
I currently have my standard Arris wifi gateway from Cox. I am not getting great upload speeds to my xbox but I am getting almost 100% download speeds and signal strength on wifi.  I am looking to upgrade my router but here is the issue.  I can not hardwire the xbox for location reasons and it is also in a sperate room give or take about 40 feet from the gateways location.
I know the XR500 is for gaming and all, but to be honest signal strength is more important to me. What is the point for all the gaming options if I cant get the signal to the device I am gaming on?
My question to anyone who may be able to give me an answer is, which router will give me the best wifi signal strength through walls/kind of far away?
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 4
schumaku
Guru
Re: XR500 or X10 wifi signal strength?
Honestly? Install a network cable.
Still insist of doing wireless? Deploy access points (again cables...) in small cells to the same room where you expect the best wireless coverage.
Message 2 of 4
myersw
Master
Due to government regulations no manufacturer can build a router that exceeds transmit power specifications so you will not see a big increase with a particular router over another.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 3 of 4
schumaku
Guru
Beyond, both the XR500 and the R9000 make use of the very same Qualcomm QCA9984 radio controllers and Skyworks (2.4 GHz) resp. RFMD/Quovo (5 GHz) power amps.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 776 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
