Orbi WiFi 7 RBE973
Xbox one best settings?
NUKLRSOLDR
Guide
Bottom line up front: I am in search of the settings that provide the best online experience specifically for Advanced Warfare (single xbox setup). I.E. provide the lowest latency experience.
No I am not having any significant issues and yes I have the latest firmware. And I have the xbox setup with a reserved IP address (Static IP). I connect with a wired connection using CAT 6 Cables from modem to router and router to xbox. I have Home Telecom for ISP from Moncks Corner SC, I have cable internet 50 mbps down and 10 mbps up.
Things I wish to address/ ask questions about:
Question #1: UPnP, Port forwarding, or DMZ? I can get an open NAT with any of these but which one will provide the lowest latency?
Question #2: Firewall, what are the best settings for xbox live? And if DMZ is used do these settings even matter?
Question #3: MTU some claim this makes a difference I have played with it but can't tell for sure if it affected latency. Will it improve latency to change the MTU to something lower than the default 1500?
Question #4 (Big Question): QoS, First of all the 2 besides the upstream. Wireless WMM, enable or dis enable? Downstream, I notice a custom rule can be setup to the xbox's MAC address, would this help or make latency worse? And finally, the upstream QoS, enable obviously....
Click Qos priority rule list; setup QoS rule and it shows the current rules and allows more to be created. By default xbox applications is only set to high while Skype and other useless things to me are set as highest. I changed everything that was preset as highest to high except for Netgear EVA (Not even sure what that is, anyone know?). And I set the xbox rule to Highest. So in summary Xbox and Netgear EVA are the only two set to highest everything else is something lower.
So to sum up Question #4: did i do more damage than good or is there an even better setup for this? I noticed I can setup custom rules and even just setup rules for the LAN port or MAC address, would either of those be better options?
Question #5: I know when setting up most QoS you have to put in your bandwidth and it must be something lower than your actual or else it all falls apart. (I.E. i get 10 mbps upstream, when I enter my upstream bandwidth in the router I must put something lower than what I actually get. Speed test vary from about 8 to 9 mbps, therefore i must put a value into the router no more than 😎 When I click the button for speed test it auto puts in about 9.66 mbps. but i know sometimes i get less than that from my isp especially during peak times. So I conservatively set the upstream in the router to 8, does anybody see a problem with this or know why this QoS system would be different from others?
Recap: Upstream bandwidth actual vs. value place in router.
Question #6: Will turning off the wireless radios improve the wired connection latency or stability? and if so, would using a second router as an access point to handle the wireless side be a good option?
Question #7 (Last one): DNS servers. I can change them on the xbox itself, would it make any difference for the xbox if;
I let the xbox get DNS automatically and changed the router's DNS to google's (8.8.8.8),
rather than leaving the default ISP DNS in the router and manually changing them on the xbox to google's DNS?
Okay, so a lot of questions, I am not here to argue about the placeable effect and yes I understand that lag cannot be completely gotten rid of and it depends on many factors. The defaults work just fine but I have been playing Call of Duty for many years now with multiple ISP's and many different routers and setups I have learned that tweaking a setup just right gives people with no skill (like me) a nice advantage in most games. And if you combine the right setup with actual skill, well....You have all seen that person that is impossible to kill and you swear is hacking so you report them, but guess what they were not hacking. I know because I had a good setup once with verizon Fios and i was accused of cheating all the time. Unfortunately I cannot get Fiber optic internet where I live now.
Also, with everything I have tried so far, the Nighthawk is by far the best router I have ever used and I have already improved my average K/D after owning it for only a few days now.
Message 1 of 34
Accepted Solutions
NUKLRSOLDR
Guide
Re: Xbox one best settings?
So with Black ops 3 coming out I wanted to make sure I was going to get the best experience that I could.
I did a lot of sole searching and research made the changes and did a proper reboot. So far my online experience is awesome and is like night and day compared to playing advanced warfare. I'm not sure if Black Ops 3 is the only reason or not but I will detail below what is currently working great for me.
On my modem (standard Xfinity modem/router with the 90/15 gb plan) I turned off the firewall completely and set to bridge mode. Then plugged my router into it. For the modem settings for me it was 10.0.0.1 and default username and password (admin and I can't remember PW but you can google it if you have Comcast.
On the nighthawk.
I updated the firmware.
Updated my time zone in the security menu.
Changed the DHCP reservation range to a max of .100
Setup Xbox with a reserved ip (static ip) of .150 (well outside the range of the reserved ips)
Setup port forwarding to the Xbox with
TCP: 80
UDP: 88, 500, 3544, 4500
Both: 53, 3074-3075, 3076, 1863, 16000
I left upnp on
Disabled SIP and set to open
Turned on upstream qos and used the built in speed test to set upload bandwidth.
Edited all default rules with a highest priority and changed to a high priority.
Changed the default Xbox priority from high to highest.
And set up a custom rule to my Xbox MAC address with highest priority.
On the Xbox:
I turned off Kinect and DVR
Left network ip settings to get automatically
But set dns manually (I use 8.8.8.8 and 8.8.4.4)
On my TV:
Game mode on
All reductions and motion smoothing off.
If you have the option choose refresh rate as close to 60 hz as possible
Proper reboot after all settings changed:
Unplug router
Then unplug modem
Then fully turn off Xbox (hold power button until it turns off)
Wait 1 minute then turn on Xbox
After Xbox is on wait at least 5 minutes before plugging in modem.
Wait for modem to fully turn on
Then plug in router and wait for it to fully turn on
Once Xbox connects to XBL go to network settings and run multiplayer test. After test hold all triggers and bumpers until the next screen pops up.
Some of this may not matter but it's what I did and knock on wood I continue to have an amazing experience as I have had so far with black ops 3.
Message 25 of 34
All Replies
MetroStar1974
Novice
Many questions, short answer! 😄
I have only set NAT as open under WAN settings and deactivated UPnP. I do not have any issue in online gaming on Xbox or PS4!
The DHCP service of my router is administrating all my devices withput any problem.
I only modify router settings if I remark a connection problem, but as I do not have any problem, I did not make any modification in my router. Mainly you need only to activate UPnP, if you have connection errors during online gaming on your console.
QoS is disabled as my down- and upstream is so huge that the router will not have problems to manage my down- and upstream. But if you want to do activate QoS, then activate it... 😄
If your upstream is lower than 2.5 Mbit/s than probably QoS should help. But if it is 5Mbit/s or even more then you should not need QoS. Only if you execute high-speed downloads with other devices during online gaming on your console, then QoS will help your router to avoid lags or game-server disconnects of your console. Check and then decide what is the best set up for your router.
Message 2 of 34
wolfn
Really? You didn't activate UPnP in your Router?
What is your PS4 connection test result, due to NAT-Type UPnP and "maybe ip fragments" problems?
kind regards
Message 3 of 34
MetroStar1974
Novice
kind regards
Yes, UPnP is disabled. No port forwarding rules set. My connection test result is absolutely normal. Downstream is approx. 45 Mbit/s and the upstream is like 5 to 6 Mbit/s. But his depends how busy are the PSN servers. NAT type is 2.
The "IP fragments" message is caused by PSN and not by the router or your ISP.
I change only settings, if I have connectivity problems or if a message appears during online gaming.
Message 4 of 34
NUKLRSOLDR
Guide
Thank you MetroStar1974 for the reply and you as well wolfn.
-wolfn; I do not have PS4 so I can't help you, I would suggest starting your own thread if you are having problems.
-MetroStar1974 you didn't really answer anything but thanks for trying, as I stated before I had no issues with default settings my quest is to improve latency that is all.
Although I had no problems with default settings I noticed a huge improvement in COD Advanced Warfare after changing some settings (Yes thats right open NAT does not mean your connection is the best it can be) This is what I have done with good results:
under advanced settings; WAN settings;
Disable port scan and dos protection checked
Default DMZ checked and my xbox's static ip address entered
Respond to ping on internet port and Disable IGMP parodying both unchecked
MTU default 1500
Disable SIP ALG checked then to the right open selected
Advanced settings; LAN setup:
at the bottom add reservation setup a static ip address
Advanced settings; QoS settings:
For upload check enable upstream QoS (optimized for gaming)
then click Setup QoS rule and delete all except for the xbox and Netgear EVA rules and change the xbox priority to highest and netgear eva to high.
The only other things I changed which should have no impact was the system time, wifi name and password router login password
Everything else is default UPnP enabled by default (shows xbox ip and port 3074 in the list) and I have no port forwarding rules setup.
Again I had open net and connected just fine without changing anything, however in games such as COD every millisecond counts and I noticed a big improvement with the above setup vs. defaults.
I hope this helps, again I do not claim to know much about routers, but please do not post unless you have something about improving latency beyond "Works Fine".
I'm also not here to argue if you search the internet deep enough you find posts from people who actually understand what is going on when you change different things but even people at that level don't agree about everything. At the end of the day you just have to try different things and see what works, keeping in mind that you can't completely get rid of lag and many things affect it such as time of day and even the TV that you use (if you don't know what I'm talking about look up TV input lag).
Message 5 of 34
NUKLRSOLDR
Guide
-MetroStar1974
Correction to my reply, you did answer a question about the WAN settings but you brought up another with it. I understand setting NAT to open, that is even on the xbox website for setting up this router. Was it necessary to disable UPnP? Did you try with it enabled first and then changed it because it caused lower latency or issues?
Message 6 of 34
NUKLRSOLDR
Guide
One other thing about upstream Qos is that I get 10 up from isp and by running speed check I get about 9. The value I set is 8 because it is required to input a lower value with most qos engines. It must have something to throttle therefore if you use 10 as the max but at the moment your isp is only giving you 8.5 then the engine doesn't work properly. If anybody knows if this qos engine is different please explain.
Message 7 of 34
MetroStar1974
Novice
Ok! You can also use your settings. Every connection is different and therefore the settings of your router could be also different for a better connection amd better latency.
I remarked that I improved speed and latency to the best using Google DNS. (my first DNS server is 8.8.4.4 and second server is 8.8.8.8, but you can also try to use it vice versa)
Message 8 of 34
NUKLRSOLDR
Guide
I guess I'm having trouble reading where you said that, but anyways I'm not here to argue.
To clarify, Yes I agree Google DNS provides lower latency than my isp defaults. So this is what I'm trying to ask:
You can change the router DNS servers to google say 8.8.4.4 as primary
You can also change the DNS servers in the xbox through manual assignment, now when you do this the xbox will use whatever dns servers you input to the xbox regardless of what the router dns servers are.
Setting google dns servers in the router settings for both of the following scenarios;
Scenario 1: Xbox dns set to automatically grab from router, when you look in the network settings usually it will just show the 192.168.1.1 as the dns server when using this.
Scenario 2: Xbox dns set to manual assignment and then use google dns, now the xbox will use google dns no matter what the router dns settings are.
and when checking network settings will actually show the google dns servers.
So if by doing scenario 2, the xbox is somehow bypassing the router for dns resolution, then that would theoretically lower latency. or perhaps it still goes through the router and actually causes more latency by confusing things with the router settings. (similar to UPnP and port forwarding confusing each other).
Personally through my testing it seems a little better by setting it manually in the xbox vice the router, but testing takes many days to get a good idea of the actual difference, and is therefore far from complete.
I know its confusing because I am asking some off the wall questions and I am not sure what the best way to ask them is, so I hope this clarifies my question about DNS. And PLEASE don't respond to argue, only if you wish to add constructively to the purpose of this thread, otherwise start your own.
Opinions are welcome but I was more hoping that people who understand this stuff (I.E. have gone to school for this type of stuff) would give some reasoning for why one setting might provide lower latency than other settings, etc.
Message 9 of 34
NUKLRSOLDR
Guide
New Update important! Although everything worked like a dream at first i kept running into more and more issues. I checked the router log and saw many many unusual ports being opened to the xbox one (192.168.1.8) ports that are not used by xbox live.LAN access from remote] from 61.160.224.130:38426 to 192.168.1.8:32764, Friday, Dec 19,2014 09:34:47 [LAN access from remote] from 151.236.42.10:12861 to 192.168.1.8:5631, Friday, Dec 19,2014 09:32:38 [LAN access from remote] from 61.160.224.129:60069 to 192.168.1.8:8080, Friday, Dec 19,2014 09:31:26 [LAN access from remote] from 122.225.97.91:6000 to 192.168.1.8:22, Friday, Dec 19,2014 09:26:25 [LAN access from remote] from 162.253.128.163:13614 to 192.168.1.8:23011, Friday, Dec 19,2014 09:24:10 [LAN access from remote] from 192.210.233.162:33171 to 192.168.1.8:1900, Friday, Dec 19,2014 09:22:12 [LAN access from remote] from 60.173.11.195:6000 to 192.168.1.8:9064, Friday, Dec 19,2014 09:16:52 [LAN access from remote] from 195.64.208.167:29873 to 192.168.1.8:23011, Friday, Dec 19,2014 09:14:46 [LAN access from remote] from 218.77.79.43:54421 to 192.168.1.8:3389, Friday, Dec 19,2014 09:14:37 [LAN access from remote] from 89.46.100.25:54955 to 192.168.1.8:9064, Friday, Dec 19,2014 09:13:23 [LAN access from remote] from 222.244.215.213:55247 to 192.168.1.8:23, Friday, Dec 19,2014 09:12:26 [LAN access from remote] from 112.85.42.106:52982 to 192.168.1.8:9064, Friday, Dec 19,2014 09:10:40 [LAN access from remote] from 162.253.129.202:13614 to 192.168.1.8:23011, Friday, Dec 19,2014 09:09:30 [LAN access from remote] from 60.173.11.195:6000 to 192.168.1.8:9064, Friday, Dec 19,2014 09:07:09 [LAN access from remote] from 93.174.93.106:53672 to 192.168.1.8:143, Friday, Dec 19,2014 09:05:46 [LAN access from remote] from 107.160.10.74:46557 to 192.168.1.8:3128, Friday, Dec 19,2014 09:05:34 [LAN access from remote] from 89.99.0.16:57430 to 192.168.1.8:23011, Friday, Dec 19,2014 09:03:40 [LAN access from remote] from 121.125.71.200:9090 to 192.168.1.8:22, Friday, Dec 19,2014 09:02:52 [LAN access from remote] from 63.141.246.107:12200 to 192.168.1.8:9064, Friday, Dec 19,2014 09:00:45 [LAN access from remote] from 66.240.236.119:22552 to 192.168.1.8:1234, Friday, Dec 19,2014 09:00:16 [LAN access from remote] from 93.174.93.106:53672 to 192.168.1.8:22, Friday, Dec 19,2014 08:59:18 [LAN access from remote] from 184.75.211.244:13614 to 192.168.1.8:23011, Friday, Dec 19,2014 08:58:34 [LAN access from remote] from 189.68.182.204:6881 to 192.168.1.8:23011, Friday, Dec 19,2014 08:52:39 [LAN access from remote] from 218.77.79.38:34876 to 192.168.1.8:3306, Friday, Dec 19,2014 08:52:03 [LAN access from remote] from 60.173.10.166:6000 to 192.168.1.8:9064, Friday, Dec 19,2014 08:50:55 [LAN access from remote] from 218.150.191.216:1548 to 192.168.1.8:53413, Friday, Dec 19,2014 08:49:23 [LAN access from remote] from 50.56.25.41:2900 to 192.168.1.8:445, Friday, Dec 19,2014 08:47:46 [LAN access from remote] from 122.225.109.202:6000 to 192.168.1.8:22, Friday, Dec 19,2014 08:44:02 [LAN access from remote] from 60.173.11.227:6000 to 192.168.1.8:9064, Friday, Dec 19,2014 08:41:44 [Time synchronized with NTP server] Friday, Dec 19,2014 08:41:31 [Internet connected] IP address: 98.124.111.89, Friday, Dec 19,2014 08:41:26 [LAN access from remote] from 95.31.167.239:11660 to 192.168.1.8:23011, Friday, Dec 19,2014 08:38:35 [LAN access from remote] from 108.61.126.52:2536 to 192.168.1.8:3389, Friday, Dec 19,2014 08:36:31 [LAN access from remote] from 203.50.20.254:53 to 192.168.1.8:12883, Friday, Dec 19,2014 08:36:14 [LAN access from remote] from 186.89.118.198:2780 to 192.168.1.8:445, Friday, Dec 19,2014 08:35:25 [LAN access from remote] from 122.225.109.115:6000 to 192.168.1.8:22, Friday, Dec 19,2014 08:34:56 [LAN access from remote] from 115.186.104.244:4973 to 192.168.1.8:445, Friday, Dec 19,2014 08:34:46 [LAN access from remote] from 23.94.149.242:42700 to 192.168.1.8:80, Friday, Dec 19,2014 08:34:22 [LAN access from remote] from 137.63.74.210:13614 to 192.168.1.8:23011, Friday, Dec 19,2014 08:33:21 [LAN access from remote] from 212.57.16.98:38793 to 192.168.1.8:8080, Friday, Dec 19,2014 08:24:55 [LAN access from remote] from 162.219.179.100:13614 to 192.168.1.8:23011, Friday, Dec 19,2014 08:23:16 [LAN access from remote] from 89.46.100.25:32864 to 192.168.1.8:9064, Friday, Dec 19,2014 08:21:42 [LAN access from remote] from 61.174.50.188:6000 to 192.168.1.8:22, Friday, Dec 19,2014 08:18:56 [LAN access from remote] from 61.160.224.129:34626 to 192.168.1.8:3389, Friday, Dec 19,2014 08:18:41 [LAN access from remote] from 203.191.150.102:5498 to 192.168.1.8:3389, Friday, Dec 19,2014 08:17:00 This went on for quite some time, And I believe it may have been what was causing me problems. there is another thread for the r7000 about unauthorized access, and it appears that this problem may extend beyond using DMZ. I am not sure but until more is known, I do not suggest using the settings that I suggested for WAN settings, UPnP, etc.
Message 10 of 34
NUKLRSOLDR
Guide
Ok this is what I'm trying now and has been working very well (not as well as in DMZ, but oh well)
I setup a static ip address (DHCP reservation) in LAN setup
QoS setup: WMM both disabled/not checked, downstream disabled/not checked,
Upstream enabled/checked (I get 10 up from my isp but i enter 8 into the router) many people with actual knowledge of qos engines will tell you to only input a value of 80% - 95% of what you actually get. If you prefer to throttle to the point that you won't be used as a host then put this value to something below that which will automatically disqualify you from host. (I don't know what value that is)
And the most important WAN settings/ Firewall settings:
Everything is not checked except for the bottom one
The only thing that should be checked is Disable SIP ALG then check open instead of secured.
To clarify what is not checked is:
Default DMZ server
Disable IGMP proxying
Under advanced setup disable UPnP and delete all port forwarding rules.
Now if you were paying attention i have no UPnP, no port forwarding and no DMZ and I still get open NAT with this router. If you have a different router then you may need to use ONE of those (but only one).
DMZ gave me the lowest latency but it also allowed attacks that seemed to destroy my games, when I was not being attacked however it gave me some of the best games I have every had in any COD game.
It seems I get better latency by setting google dns servers in the xbox network settings, so i would suggest doing that even if they are the same ones you use in the router. Meaning don't let the xbox get them automatically from the router as this seems to increase latency a little bit.
Other things to consider if you are having problems:
Input lag of your TV, I personally spent a lot of extra money to ensure I got a TV with low input lag (only works when i use the "game mode" however)
I also had a lot of issues once and found my xbox was connecting wired and wireless at the same time, clear the wireless settings if this is happening to you as well.
Message 11 of 34
MatM
Guide
If you run the Multiplayer test on xbox one anf ater Testing you press all four Buttons (RT/RB LT/LB) you get a Statistc for you are not behind a cone nat or you are behind a cone nat.
What I saw: My games get better if I port forward 3074 TCP/UDP for my xbox.
My NAT is open and I port Forwarded this port. It runs good at the moment.
I don't know if you also have IPv6 available. If yes you should enable
"Respond to ping on internet port" because it's needed.
What I read about is also that path MTU needs ICMP Packets for working correctly. So I enabled the ping request on WAN.
see also:
http://packetlife.net/blog/2008/aug/18/path-mtu-discovery/
https://en.wikipedia.org/wiki/Path_MTU_Discovery
It seems that there is no Security benefit if you disable "Respond to ping on internet port". But experts argue about it and I'm not an expert.
I enabled it because I think I need path MTU because of all the different connections you get on p2p games like call of Duty or FIFA or PES and so on 🙂
Message 12 of 34
NUKLRSOLDR
Guide
MatM,
When I run the test it says I'm behind a cone NAT.
With the nighthawk router and current firmware, if i port forward then I get attacked by unauthorized access attempts, even if i use UPnP this happens. Luckily I still get open nat without using either of them. And then I no longer see the attacks in the logs.
No unfortunately I can't get IPv6 yet. Hopefully soon.
As far as the respond to ping request Netgear has this to say: Respond to Ping on Internet Port. This feature allows your router to be discovered. Use this feature only as a diagnostic tool or if you have a specific reason.
I will try to enable it and see if it makes an improvement for latency without allowing attacks.
I have tried lowering my mtu to 1452 as that is the largest one without fragmenting for me. I also tried going to the minimum for xbox live but didn't notice a difference in COD, but did notice webpages and such taking longer. I can't say for sure if it has made a difference in latency, I also hear that the packets in games like call of duty are all much less than the minimum required for the xbox one anyway.
Thanks for the response, I will post again if I notice a difference with the respond to ping setting.
Message 13 of 34
MatM
Guide
If I run the test I get. I'm not behind a cone Nat. Even if I port orward.
If I use UPnP I also get attacked and my logs show me that differen IPs gets access on times I'm not online 😞
If I use port Forward I get attacked only on port 53, 80, 3544.
The Port 3074 never gets attacked.
If 1500 is not the best setting for you i means you are not on cable Internet? So you have DSL? With pathmtu it should find the best mtu settings for you automatically. I have enabled ping request on Internetport on all my routers an never had a Problem with it.
you can also read here 🙂
http://blogs.cisco.com/security/icmp-and-security-in-ipv6/
Message 14 of 34
NUKLRSOLDR
Guide
From my understanding of NAT is that it was created for IPv4 because IPv4 was outdated and it extended the live of IPv4. Since you use IPv6 wouldn't that explain why you are not behind a NAT? Even after I enabled respond to ping on internet port I am still behind a cone NAT but I believe that is as good as it gets with IPv4.
So you are not concerned about the attacks on ports 53, 80, or 3544?
With UPnP you were attacked on more dangerous ports?
I do have cable internet, but I had read some different things about changing mtu to your "optimum mtu" by doing ping tests in the computer console and slowly lowering the mtu of the test until no fragmenting would occur (max mtu without fragmenting). When I did that I found that after adding the 28 or whatever they say you have to add to the result of that test, my optimum mtu was 1452. But I didn't seem to make a difference for me and other stuff i read says to leave it at 1500 so I put it back at 1500 and most likely won't be messing with it anymore.
After initial testing of enabling respond to ping request on internet port, Latency seems very much improved, it also feels laggy but in a good way, as my K/D has improved tremendously on a regular basis and when starting games i get in with the countdown often starting from 15 now instead of 3-10 normally before.
Also after playing all day and checking the logs I did not see any attacks.
So thank you very much for that advice, I hadn't really read anything about it before. But It might be what I have been searching for for years.
With my previous post talking about upload QoS, I think I forgot to mention that I deleted ALL of the default rules and setup one custom rule to my xbox's MAC address. I have heard that setting to the Mac address gets priority (possibly lower latency) and in my testing it definitely did not make it worse.
Message 15 of 34
MatM
Guide
I deleted the port forwarding for those ports. I forward all other suggested ports but not 80, 53 and not 3544 🙂
Message 16 of 34
MatM
Guide
how do you setup your qos?
Your XBOX with high settings via MAC Adress? Do you configure all other things also? I have configured www for normal queue. And DNS for highest.
How do you setup it right? and how is it right if I want all other traffic in a low priority queue? Do I have to setup a config for it or is all not matching any rules low priority?
Message 17 of 34
NUKLRSOLDR
Guide
This is what I did, but I don't care about anything but the xbox. I disabled the WMM (wireless) QoS. And I left the downstream disabled, which is default.
With Upstream i enabled it, and where you input your max upstream bandwidth, don't actually input your max input 80-95% of what you get from doing speed tests. I get 10 mbps from my isp but i enter 8 into this part of the router. From other qos engine setups this has to be lower than your actual or the qos engine won't work properly.
I went to setup rules and deleted all of the defaults. and setup one custom rule to my xbox's mac address, giving it highest priority.
Anything that does not have a rule setup for it will be given "best effort" priority by default, which I believe is the same as "normal".
I don't care about anything but my xbox, I don't use my internet to the extreme that I am always maxing out my connection, but if you wan't to feel free to setup whatever rules you desire. the rules will limit how much bandwidth can be used for different priorities but it also determines which packets will be processed and sent along their way sooner, think of setting priority to highest as being able to cut in line in front of everything that is not set as highest, (head of line privilages) if you have more than one set to highest however they will be dealt with most likely in the order they are received. I could be wrong but that is how I understand basic qos.
For me I wan't my xbox to have head of the line privileges at all times and Get as much bandwidth as it wants regardless of what else is happening on my network. When i am gaming I don't really care if my girlfriend surfing the web has to wait an extra second for her webpage to load. Get what I'm saying? But I am just a basic user who loves Call of Duty.
I did try DD-WRT (kong's latest build) and setup that qos engine exactly according to the official forum, but it did not perform nearly as well for my xbox in call of duty, so I quickly switched back. But who knows it could have just been a bad firmware load that could have been fixed by trying again, but I didn't bother to try.
Message 18 of 34
MatM
Guide
and last thing I want to know. Do you play wireless. And why do you disable WMM? I read also that often users whio play online even if they play wired disabled wmm and their experience is better. Yesterday I disabled WMM and my connection to xbox live feels better (but I don't know why because I play wired). I'm not sure if it is placebo 🙂
Message 19 of 34
NUKLRSOLDR
Guide
As far as I know, It is just qos for wireless, whenever you have a qos rule setup for something, it reserves some bandwidth for it, even if it is only a little bit. I play wired, so I disabled WMM because I do not want anything wireless to have any above normal priority or any reserved bandwidth, so that the qos can focus on my xbox instead of other things.
I am also not sure if it actually makes a difference, but it definitely didn't hurt as far as I can tell.
On another note, I found that if I disabled port triggering (on by default) that I was not seeing attacks in the logs with UPnP. I am going to try with port forwarding instead of UPnP and see if i get attacked.
Message 20 of 34
ghobson28
Keep up the good work guys, I got a lot of useful information from your posts. I have Xbox One and Ps4 and I have the best connections when I disable Ports can and Dos protection, with Nat open checked and Sip disabled. I direct connect like quality when I use dmz on one of the consoles. I really want to try my connection with Upnp disabled but I have multiple consoles: 3 Ps4's, Xbox One, and 4 Xbox 360's. So I can't disable this feature. From my experience Upnp adds latency while dmz doesn't. But I will try Qos and see what my results will be, even though Microsoft says not to use Qos.
Message 21 of 34
MatM
Guide
I disabled QOS because I get Problems with QOS enabled.
I had only my xbox in the rules. But on this test (Quality-Test):
http://myspeed.visualware.com/index.php
(Jave needed or if you use Linux IcedTea-Web have to be active)
My line gets not good. The Test shows me that my packets are out of order (on PC). This should not be a Problem but because of out of Order I have thousands of Packets retransmittet and several hundred packets my PC wants to have again because of that. It increases bandwith very much so I disabled QOS. (This ist not good !)
I don't understand why the Problems are there because as I chekced only my PC was online. But with disabled qos - all is good now and no Packets are lost or out of order 🙂
Not sure if it's only a problem on my line with cablemodem and R7000.
Message 22 of 34
MatM
Guide
since google and akamai uses edns - you can always use it and should get the nearest downloadserver from akamai. XBOX live works in some parts with akamai.
http://googlewebmastercentral.blogspot.de/2014/12/google-public-dns-and-location.html
Message 23 of 34
MatM
Guide
ok - new one 🙂
I have disabled game DVR and I have disabled Kinect completely.
Games like PES 2015 runs much better now. Today I had not as much Button lag like I always have on PES 2015.
Even I have to change from wired to wireless (5Ghz) but I think to disable Kinect (system Settings) and Game DVR helps alot.
Message 24 of 34
NUKLRSOLDR
Guide
On the nighthawk.
TCP: 80
I left upnp on
On the Xbox:
On my TV:
Game mode on
Unplug router
Then unplug modem
Message 25 of 34
Top Contributors
Discussion stats
  • 33 replies
  • 1265552 views
  • 6 kudos
  • 7 in conversation
Announcements
Orbi WiFi 7
