Reply
Xfinity IPv6 Configuration
MarkBond
Which setting should I use when configuring the LAN IPv6 IP address assignment:
DHCP Server or Auto Configure?
Comcast Xfinity is my ISP.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 9
microchip8
Master
Re: Xfinity IPv6 Configuration
DHCP
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400 - Cruncher: Intel Core i5-7400
Message 2 of 9
MarkBond
I’m asking about the LAN device IPv6 address assignment setting, not the type of IPv6 connection which is DHCP. The choices are use DHCP server and Auto Configure. This configuration is under LAN setup. From what little information I can find, using the DHCP server to assign the IPv6 addresses to the devices on the LAN supplies them with more info than the Auto Configure setting but is not supported by all ISPs.
Message 3 of 9
microchip8
Master
ISPs have nothing to do with the LAN side IP assignment. If you get an IPv6 prefix from your ISP on the WAN side and if you don't have a good reason to use DHCPv6 on LAN, use SLAAC instead (Auto Config). SLAAC is made of the IPv6 prefix you get and the rest gets "made" by the computer itself (consisting of the date with privacy extensions)
If you have Android devices at your place and want them to also have an IPv6 address, your only option is SLAAC since Android doesn't support DHCPv6 (yet)
Message 4 of 9
microchip8
Master
Correction, SLAAC is IPv6 prefix + the rest made of the date, MAC address and privacy extension
Message 5 of 9
Guru
I'm on xfinity and just use auto-configure. its worked everytime through multiple routers/setups.
Current Setup: CM2000-> SXK30-> GS716v2-> Arris W31 x2-> Pi-hole->
Message 6 of 9
I'm using Auto Config.  No issues with IPv6.  My LAN devices get both assignments where supported.
My Androind phone included.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 7 of 9
MarkBond
Thanks for the info,still experimenting and it looks like Apple devices can't get an address with the DHCPv6 client server.
Message 8 of 9
MarkBond
Update
The Apple devices do get ipv6 addresses when the router is set to use dhcp to serve them to the lan devices but after a while those addresses won't route. Acts as if the devices and router lease times might be out of sync.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2753 views
  • 2 kudos
  • 4 in conversation
Announcements
