Reply
Highlighted
Zeiteinstellung Time adjust R7500
hallo
ich habe einen R7500 und habe heute gesehen , das die Sytemzeit 1. Januar 1970  12.28 Uhr ist. Wo kann ich die Systemzeit einstellen ?
Eigentlich soll diese sich automatisch einstellen , tut sie aber nicht , auch nicht nach einem Neustart. Wer kann helfen ?
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 10
Highlighted
Master
Re: Zeiteinstellung Time adjust R7500
Please speak English. This is an English-only forum
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.80SF
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400 - Cruncher: Intel Core i5-7400
Message 2 of 10
Highlighted
Sorry , i will change it.
i have a Netgear R7500. Today I saw that the System date and time is 1. of january 1970 12.29 p.m.
Where can i adjust the systemtime ? It shoud happen autumatically , but it doesn`t happen even by rebooting or disconnecting thr router from power for one night.
Who can help me ?
Message 3 of 10
Highlighted
Master
-select advanced tab
-select security
-select schedule
-select time zone
Message 4 of 10
Highlighted
I did so , but the time didn`t change
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 5 of 10
Highlighted
Master
did you enter an NTP server? Rebooted the router after that?
Message 6 of 10
Highlighted
I read of this , but where and how can i do this ?
Message 7 of 10
Highlighted
Master
Hi wolfgangbrodda,
1. What is the firmware version of the router?
2. Try to reset the router to factory default and reconfigure.
JamesGL
Community Team
Message 8 of 10
Highlighted
hi
The R7500 has the firmware 094 , resetting to factory defaults does´t solve my problem. I called up my provider with my problem.He told me, that all NTP-Server are blocked by them because of a lot of DDOS-Attacks in the last time. If i want to hafe the correct Time in my router i have to use their own NTP-Server.
But that is not possible for me because i cannot put this adress into the firmware of my R7500.
Wolfgang Brodda
Message 9 of 10
Highlighted
Master
Hi wolfgangbrodda,
If that is the case then your ISP is the cause why the router will not get the correct NTP.
JamesGL
Community Team
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2939 views
  • 0 kudos
  • 3 in conversation
Announcements
