Reply
Highlighted
ac1900 r7000
i need help on how to set this up  i bought it used didnt have no directions
so im stuck on configuring this to or what settings i should use to make the best of this
and settings for my ps4 for gaming
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 3
Highlighted
Luminary
Re: ac1900 r7000
Go up to the top of the page and click on DOWNLOADS.  Enter the product number of your device.  On the left hand side you will see three PDF documents you can download and read.  They are Product Data Sheet, Installation Guide, and User Manual.
Make sure you read the model number off of the label on the device.  Otherwise you will not get the correct documents.
Message 2 of 3
Highlighted
Re: ac1900 r7000
ok thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 181 views
  • 0 kudos
  • 2 in conversation
Announcements
