Reply
ac1900
wowowow
Follower
ac1900
i lost my password and code to get this going again. I moved and misplaced this info  for model ex7000 range extender
 serial number 46D1517da1f4c
Secr
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
antinode
Guru
Re: ac1900
> [...] model ex7000 range extender [...]
   Hardware version (EX7000 Plain/[v1] or EX7000v2)?
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Read.  Look for
"Return the Extender to Its Factory Default Settings".
Message 2 of 3
Re: ac1900
If you have the EX7000, and not the R7000 listed in your footer, you have posted your message in the section of this community given over to Nighthawk WiFi Routers.
Your devices is a WiFi Range Extender.
You might get better replies, and find other answers, over in the appropriate section:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
But the advice is probably the same.
There is a manual for the EX7000 somewhere at the end of this link:
>>>> EX7000 | Nighthawk WiFi Range Extender | NETGEAR Support <<<<
See the section Return the Extender to Its Factory Default Settings.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 237 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
