Orbi WiFi 7 RBE973
Reply
access control
overbet
Tutor
access control
This is for Nighthawk X10 R9000 not 7200.
When I try to use access control or see connected devices the pages load and then produce a balnk page upon completion. I set up the router and blocked new devices now I cant undo that to allow a new one because the page wont load. Any suggestions besides a factory reset. That would be a lot of work which Im not really a fan of.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 5
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: access control
We are working on the issue for the attached devices on the R9000.
DarrenM
Message 2 of 5
All Replies
DarrenM
Re: access control
DarrenM
Message 2 of 5
Firefox473
Initiate
Re: access control
Has this issue been solved yet?  It has caused me lots of problems for a very expensive router
Message 3 of 5
myersw
Master
Re: access control
Don't know about the r9000, but Voxel fixed the blank device screen for the r7800.
I would give his firmware a try. Installs just like doing a manual upgrade/downgrade of OEM firmware and looks the same.
Link to Voxel firmware.
https://www.voxel-firmware.com/Downloads/Voxel/html/index.html
Message 4 of 5
overbet
Tutor
Re: access control
Sorry no, I ended up doing a reset.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1621 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
