Orbi WiFi 7 RBE973
Reply
add RBR50 a backup dongle 4G
Thomas_FR
Follower
hy,
(i'm french).
i would like to know how it's possible to add to my RBR50 a 4G cellular backup?
the objectif is to switch to the 4G cellular connection when the main internet connection ADSL doesn't work.
thanks for your helps
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Guru
Re: add RBR50 a backup dongle 4G
the RBR50 doesnt have the option of dual wan or LTE failover.
Message 2 of 3
Guru
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
@Thomas_FR wrote:
hy,
(i'm french).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 564 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
