- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
adding a gateway in r6900
- Mark as New
- Bookmark
- Subscribe
- Permalink
my setup is as follow
from fiber ONT , lan to lan r6900(not using wan) , i want to use r6900 dhcp and not my fiber ont
when i am setting up lan i cannot specify the gateway(fiber ont ip) hence i either have to setup manual gateway on all devices(which is impossible) or use ONT DHCP which i dont wanna use.
how can i setup gateway as i dont see any option in lan setup (unlike tplink) , is there a way around or some other setting which will fix this for me.
thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: adding a gateway in r6900
> from fiber ONT , [...]
What is it? Maker? Model number?
> [...] lan to lan r6900(not using wan) , [...]
If your "fiber ONT" really os an ONT, and not a NAT router, then why
would you expect that to work?
> [...] i want to use r6900 dhcp and not my fiber ont
Why? Is there some actual problem which you are trying to solve?
> [...] or use ONT DHCP which i dont wanna use.
If your "ONT" has DHCP, then it's more than an ONT. What is it?
Why the odd-ball LAN IP address?
Start again. Describe your equipment and your goals. Forget about
how you think that you can (mis-)configure the R6900 to do whatever it
is that you actually want.
