- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
are CM1100 cable modem and R8900 routers compatible?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I own an R8900 router, and I am planning to get a CM1100 cable modem. Before buying, I want to be assured t
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The r8900 should work with any modem including the cm1100.
When you are bringing to two of them up be sure to follow the following procedure.
Power down both the modem and router.
Now power up just the modem and let it stablize, about 5 minutes or so. Should be able to tell by lights.
If the router is not connected to the modem you can connect now or wait.
Power up the router. The router should see the modem and connect and have access to internet.
Now ready for config of router if you have not already done it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
