Reply
are the Nighthawk R7000 and Nighthawk C7000 comparable
picker620
Follower
I have Cableone internet and one of their recommended compatible wifi routers is the Netgear Nighthawk C7000. Cableone doesn't list the Nighthawk R7000 as a compatible model. But I found the R7000 on sale about $60 cheaper than the C7000. Will the R7000 be acceptable/desirable to use instead of the more expensive C7000? Thank you.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
antinode
Guru
Re: are the Nighthawk R7000 and Nighthawk C7000 comparable
   Define "comparable".  They're not interchangeable.  The C7000 is a
cable-TV modem+router; the R7000 is a router (with no modem).
   Visit http://netgear.com/support , put in your model number(s), and
look for Documentation.  Get the User Manual(s).  Compare.
Message 2 of 3
@picker620
Different animals. R7000 = router. C7000 = cable modem/router.
A lot of people like to keep router and modem separate. Routers are generally more versatile than modem/routers.
Netgear puts more effort into keeping routers up to date. And in the case of cable modem/router you are in the hands of the Internet service provider when it comes to firmware updates.
If you like the idea of the R7000 then you could put a basic modem only device in front of the router.
You might even get a modem for $60, although I wouldn't expect much for that price.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3016 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
