- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
asemahsamad@hotmail.com
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello
i am writing for some help please
My Netgear routerlogin online page keeps saying that my login info will be sent unencrypted so it’s not even sending my login info privately with encryption. I am not happy about this and would please like to know how to fix this. Any advice would be greatly appreciated. I have the latest firmware update on the router. It also says the same message when I try other browsers like chrome.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only time you need a secure connection is if your accessing the routers web page from a remote location on the WAN side. HTTPS should be used and should work well. When your at home, HTTP is ok to use and nothing to worry about. If your the only one managing the router, then your fine.
Browsers are just making you aware of the possible problem. They will do that if your accessing a site even on the WAN side to make you aware of possible issues. Like if you access a bank site, should always be HTTPS. Bank will not allot HTTP for example.
Your fine.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: asemahsamad@hotmail.com
Add or allow the connection in the browser. It's ok if it's secure or not secure. its only on the LAN side of the Router. Nothing happening from the WAN side.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So everything is ok I don’t need to change any settings?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you very much appreciate your explanation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
