Reply
blinking power LED, interrupted Update
Hijack
Tutor
  1. Update failed and nog power led is blinking and nothing works anymore, what van i do?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
Guru
Re: blinking power LED, interrupted Update
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-...
FYI, use the TFTP program thats included in windows. Not the one suggested in the link. It Doesn't seem to work.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 3
myersw
Master
TFTP windows program does work, But I just recovered a r8000 using the tftp32 program. Just a FYI, YMMV.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 434 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
