- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
block port
- Mark as New
- Bookmark
- Subscribe
- Permalink
block port
i added some port to block i dont know if i did right or not i attached screenhot , and those port i found in my modem log was from dos attack i thought i can block them or what i should do to stop this attacks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: block port
> [...] those port i found in my modem log was from dos attack [...]
What, exactly, was in your log? Copy+paste is your friend.
> [...] i thought i can block them or what i should do to stop this
> attacks
"ADVANCED > Security > Block Services" stops users on your LAN from
accessing services on the Internet. It does nothing about external
access to devices on your LAN.
Without seeing the messages from your log, it's hard to be sure, but
I'd guess that your router is already blocking the "attack" (if it's not
just a false alarm).
Other than the annoying messages in the log, are you seeing any
actual problems?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: block port
[DoS attack: Echo char gen] from source: 146.88.240.4, port 60693, Wed, Apr 07, 2021 17:36:10
[DoS attack: Echo char gen] from source: 142.93.193.164, port 61000, Wed, Apr 07, 2021 16:02:17
[DoS attack: Echo char gen] from source: 185.165.190.17, port 29921, Wed, Apr 07, 2021 15:13:16
[Time synchronized with NTP server] Wed, Apr 07, 2021 13:49:04
[Initialized, firmware version: V1.01.37] Thu, Jan 01, 1970 00:00:07
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: block port
> [DoS attack: Sync flood] from source: 179.60.150.81, port 65531, Wed,
> Apr 07, 2021 19:23:22
A port number like that refers to the port on the remote (attacking?)
system, not anything on your router. It's meaningless at your end.
Don't worry; be happy?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: block port
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: block port
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: block port
> How do I know if they already in my modem and that make my internet
> slow
As suggested before, these log entries do not mean that anyone is
getting into your modem. Even if these were real attacks, and not just
false alarms, you're seeing less than one per hour. I doubt that
they're causing your problem, whatever it is.
Start again. Describe your actual problem. Then both you and your
readers can worry about what might be causing it.
https://community.netgear.com/t5/x/bd-p/home-cable-modems-routers
https://community.netgear.com/t5/x/x/td-p/1530376
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Troubleshoot"?
