Orbi WiFi 7 RBE973
Reply
can't access Traffic meter
lest77
In the product guide there is a section on page 170 for "Start the Traffic Meter Without Traffic Volume Restrictions". The instructions tell you to login to the router, go to the Advanced tab and then select the Advanced Setup section. In this section there is a link to 'Traffic Meter'. This link and a few others on the page are a lighter grey than the rest. All the lighter grey links are not clickable.
Why can't I access these links?
Model: R6700v2|Nighthawk AC1750 Smart WiFi Router
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: can't access Traffic meter
Hi lest77,
If you can access the router's UI, go to advance settings and look for wireless mode or AP mode. Uncheck it.
Message 4 of 5
All Replies
JamesGL
Master
Hi lest77,
The router might be set to AP mode. When router is set to AP mode, other features will not be available(greyed out).
Message 2 of 5
lest77
Thanks for your response. How do I turn off AP mode?
Message 3 of 5
JamesGL
Master
Hi lest77,
Message 4 of 5
JamesGL
Master
Hi lest77,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 7103 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
